Note: This feature currently requires accessing the site using the built-in Safari browser.
I prefer the strip boards. Then a hand-held 3/16th inch drill bit spun in a hole to break a strip into a segment. So fast and safe vs razor blade to cut strips.assembling a project on a perfboard I purchased really cheap but it has no rails for Vdd or GRD. top layer has only holes, no markers. Bottom only has little square pads.
trying to track down circuit issues is a pain.
I second Vero (strip) Board, half way down the page https://www.futurlec.com/Protoboards.shtml
Max.
I Use an antique pin vise for the bit. I was using a tap handle but the pin vise is much easier. I recommend the vero tool if you are buying something for the task because fat pin vises are spendy.Agreed. Twist drill hurts your fingers!
This is an example. (A board to read a BME280 sensor to be read remotely via an HC-12 module. It uses a pic12f1840.)
