Joystick Theory
Pepsiiuk
Hey
For a little background; I have an analogue joystick connected to two ADCs (one each for x and y axis) which in turn (thought some process) are connected to two DACs (one each for left and right motors).
I have thought of two ways which in theory will work but in practice they didn't. The most successful calculated the % of the x and y axis and then combined them differently to achieve values for the left motors and y motors.
Has anyone any ideas/theories how to translate the readings from the joystick to values for the DACs?
Apparently it can be done using the cos and sin rules but I can’t think how.
Any ideas?
Sorry if I haven't given enough information.
Well seeing as you don't give the slightest hint about what the relationship between joysticks and motors is supposed to be, it's rather difficult to offer suggestions - other than what's with the DAC's? - sounds a very poor way to feed the motors?.
It is a poor way to drive the motors but unfortunately I don’t have a choice.
Sorry, I forgot about that. The relationships are given bellow.
joystick fwd: left motor=full fwd, right motor=full fwd.
joystick fwd right: left motor=full fwd, right motor=stop.
joystick right pivot: left motor=full fwd, right motor=full back.
joystick back right: left motor=full back, right motor=stop.
joystick back: left motor=full back, right motor=full back.
joystick back left: left motor=stop, right motor=full back.
joystick left pivot: left motor=full back, right motor=full fwd.
joystick fwd left: left motor=stop, right motor=full fwd.
However, they also have to be proportional e.g. with the joystick half forwards the motors should be motors half forwards.
I’ve been racking my brain over this for a while but I just can’t get it.
So basically you're talking about tank type steering (skid steering) from a single joystick.
There's a simple PWM example in my tutorials, which give 128 speeds both forwards and backwards for two motors using a 16F876 or similar.
It doesn't do the required maths though, although I did it ages back using the PICBASIC compiler I wrote, I'll see if I can find it?.
That would be great. Im not using any sort of microcontroller but a computer running linux to run the program but none the less it would be of use.
and thanks for the heads up on the tutorial. Ill have a look in a min.
