Jet car circuit design help Requested
go300mph
Hello I drag race jet powered dragsters .
I have basic knowledge of DC electronics, mainly automotive related and want to build a more complex circuit. I appreciate anyone who is wiling to help.
Ok I have a 12v electric solenoid = "A" circuit (open/close) I am using a bosch style 5pin relay (SPST) ((actually just am using DPST with one less lead connected))
I have another separate electric solenoid "B" circuit (right or left) I am using a bosch style 5 pin relay (DPST)
Operation 1 requires I be able to operate A circuit multiple times while B circuit is in left position
Operation 2 requires that the very next time I operate the A circuit the B circuit be switched to right simulaintiously.
I am thinking an ARM toggle switch on the dashboard that once switched then the function of A circuit now becomes A and B
monkey wrench
after I ARM then I need to be able to trigger B and if need to trigger A again it then has no effect on B , B need to then stay in the right position
HELP?!!?
Sorry but I can't quite follow all the requirements. :confused:
Could you make a sort of table that shows all the options (switch positions) and what you want to happen in each case.
This will require 3 switches: MASTER, ARM and RUN:
System OFF:
MASTER ON:
ARM ON:
RUN ON:
ARM OFF:
thanks guys let me absorb this for a bit ,
I took her out last night but the launch process is complicated and this should help
