This is how I have understood the way voltage drops work: When you ex. have a +5V voltage source, and connect a LED with a drop of 1.8V (rated at 15mA) the voltage after/behind the LED will be 5-1,8=3,2V so you'll need a 220ohm resistor arcording to Ohm's law to make the LED light at the desired brightnes.
So if you connect another LED in serie with that LED the voltage will drop further 1,8V so behind the two LEDs the voltage will be 5-1,8 -1,8=1,4V and you need a resistor at 100ohm.
If you connect a third LED, the voltage will drop to zero and the LEDs won't light up.
This right?
Cheers!
Lac.
This right?
Cheers!
Lac.
