fantabulous68
Im building an infrared liquid level detector using the Sharp GP2D12......
Photoelectric sensors are available in a variety of modes including:
* Infrared Proximity (Diffuse Reflective)
Proximity type photoelectric sensors detect the light reflected by the target itself. Proximity photoelectric sensors are preferable for general purpose sensing applications, particularly where the detected object is only accessible from one direction.
* Transmitted Beam (Thru-beam)
Transmitted beam photoelectric sensors use separate infrared transmitters and receivers. Objects passing between the two parts interrupt the infrared beam, causing the receiver to output a signal.
IS IT ACCURATE TO STATE(using the GP2D12)
An Infrared sensor is a form of a transmitted beam sensor,
if the above statement is TRUE:
Transmitted beam sensors are not suitable for detection of translucent or transparent liquids. They suitable to detect opaque liquids. My project does not work accurately with water. It works well with opaque liquids but my lecturer wants it to work with water as well. But water absorbs the infrared light. The IR light cant detect the surface of water well, it detects the bottom of the container resulting in in accurate liquid level measurements.
Grrrr i want it to be true
I know the GP2D12 works on the diffuse reflection principle but is it a form of thru beam/transmitted beam?
