Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Where is a schematic showing the input signal, the output load and the power supply voltage?
Because we do not have a clue about what you want the Mosfet to do.
But he said the positive terminal of his "object" (load?) is connected to the drain so maybe NOTHING is connected to the positive power supply voltage.
Without a schematic then we are simply guessing.
I need the PWM controller for a fan, the voltage controller is for the MIC502 and the fan.. the fan is 12V @ .62A
I noticed what I was doing wrong, long story short the voltage regulator's output was going direct to the gate pin.. but the mosfet is for the Out of the MIC502, which seems is going to need a resistor, which is 280 Ohm
The MIC502 is designed to drive a bipolar NPN transistor (as shown in the datasheet), not a Mosfet. Its output high voltage is only 3.8V but the IRF510 needs a gate high voltage of 10V.
Use a BD135 NPN bipolar transistor with a 150 ohms base resistor.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
