Ir2112 assistance would be much appreciated
doriansto
I intend using a signal generator to feed this chip, the output of which will feed 2 MOSFET drivers.
I only intend to use ONE signal source. However, the chip has a "HIN" and "LIN" at pins 10 and 12 respectively.
Is it in order to connect the signal generator (which has 3 volts square wave output) across these pins directly, or do I need to add some other method of applying a signal to this IC.
PLEASE, would members contact me directly at:
[email protected]
Many thanks for your assistance in this matter
Hello,
I was worked with that chip long time ago and finally I found that project. On next file you can see how I made circuit.
Remember that in compare to other chip such as IR2110, there is no implemented time delay for high and low MOSFET channel, so RC delay must be added.
Hope that I helped.
You notice that well...that is not correct...COM pin should be connected to ground (power ground). since this schematic was made in old Protel, I guess that some import problem to Altuim was occurred . Thank you for feedback.
