IR Repeater
Squintz
I need an IR Repeater and I have two options. I can buy IR-100 from Buffalo Electronics which allows me to connect as many Phototransistors and LEDs as I want. The problem with the is that I need help picking out the Parts.
Here is a link to the IR-100. **broken link removed**
The reason I dont want to use their parts is because they are priced at $26 for a simple IR Detector. And about $4 - 8 for an IR LED
My second option is to built the entire circuit from scratch and not use any prefabed equipment. I am not a Engineer so I am not capable of doing this without a schematic and parts list to look from. It sounds fairly simple. What goes in must come out so it seems like I would power a Phototransistor up and use it to feed an IR LED. I wouldnt have a clue how to bias the transistors tho.
So with those Options in mind I am asking you guys for help. Here is what I am trying to occomplish. I have a device called the usb-uirt from www.usbuirt.com which Receives and Emits IR signals via my computers USB connection.
THe problem is the USB-Uirt is in the basement and the devices I want to use are in remote rooms. So I need to be able to send a signal from my bedroom to my basement and have my basement send a signal back to my bedroom. I know there are options out there like the Pyrmid but I would rather run wires then do thing via RF.
1) With option one where I use the Buffalo what Detectors and Receivers could I buy from my local electronics store to ocomplish what i want to do?
2) Can someone supply me with a schematic to build my own circuit.
Option 1 is my prefered method I just need help chosing the components.
Here is an e-mail i got when I inquired about the specs for parts.
Our IR-100 is receptive to frequencies from 30 to 130 KHZ.
The IR-100 outputs (the 4 flasher jacks) the power supply voltage level (voltage regulated to a maximum of 12VDC) current limited to 20mA. The input pulse (SIG on terminal block) needs to be about 2-3V to "trigger" the transister causing an output event. The IR-100 is a digital device only passing 0's and 1's where 1's are equal to the power supply voltage level and 0's are at ground potential.
Thanks for your help
