ir 40khz decoder and encoder i want only one button latch
vishaaka
i don't know much about pic mc programming but still learning. i need help about this code in decoder mode all b ports momentary or latch but i need 7 port momentary and one port latch can be and how?:confused: please help!!
i found this code from www.rentron.com very simple both side same code
this is the picbasic code :
'* Name : IR-Chips.bas *
'* Author : Bruce Reynolds http://www.rentron.com *
'* Notes : Infrared decoder & encoder IC *
'* : For PIC16F62x & A version using 4MHz INTRC *
'* modified : Same PIC functions as IR encoder or decoder *
'* version : PM assembler. Compile size = 495 words. *
@ DEVICE MCLR_OFF, INTRC_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF
DEFINE PULSIN_MAX 3000 '// MAX wait time for pulsin
DEFINE NO_CLRWDT '// Saves 17 words code space
'// RA.6 = MODE select. 1 = decode function. 0 = encode function
'// RA.7 = LED drive or IR receive input configured by MODE
'// RA.0 = LM Latched = 1, Momentary = 0 (used only in decode mode)
'// RA.1 to RA.5 = Hardware address inputs (set same on encoder as decoder)
'// For PIC16F62x & A versions
CMCON = 7 '// Comparators Off
VRCON = 0 '// Vref Off
TRISA.6 = 1 '// Set for input. 1 = Decode ; 0 = Encode
'// Setup IR bit widths / carrier cycle times
Header CON 96 '// Header = (96 * 25uS) = 2.4mS burst
Zero CON 24 '// Zero = (24 * 25uS) = 0.6mS burst
One CON 48 '// One = (48 * 25uS) = 1.2mS burst
'// Define variables
LM VAR PORTA.0 '// Latched or Momentary mode select for decode only
Cycles VAR BYTE '// Holds number of 40KHz carrier cycles
Loops VAR BYTE '// Loop counter
Index VAR BYTE '// Index counter
IR_PULSE VAR BYTE(13) '// 13-bytes. 8 data ; 5 address
PULSE_IN VAR WORD '// Raw pulsin value
DBYTE VAR BYTE '// Holds 8-bit data byte
ABYTE VAR BYTE '// Holds 5-bit hardware address
ABYTE1 VAR BYTE '// 2nd address byte storage for verification
DBYTE1 VAR BYTE '// 2nd data byte storage for verification
H_Add VAR BYTE '// Holds "Hardware" address
X VAR BYTE '// Bit pointer for loop
'// Test for encode or decode function & configure I/O
PAUSE 10 '// Stabilize on power-up
IF PORTA.6 = 1 THEN '// Is Decode MODE selected..?
TRISA = $FF '// Yes. PORTA = inputs for 5-bit address & IR input
PORTB = 0 '// All outputs = 0 (off)
TRISB = 0 '// PORTB all outputs (8-bit data output)
OPTION_REG.7 = 1 '// PORTB pull-ups off
GOTO Decode '// GOTO Decode routine
ENDIF '// Else encode function selected
TRISB = $FF '// PORTB = 8-bit switch inputs
OPTION_REG.7 = 0 '// PORTB internal pull-ups = on
'// IRLED 170
PORTA.7 = 0 '// Transmitter IR LED = off RA.7 ----|>|----/\/\/\---gnd
'// Note: RA.7 can drive an NPN transistor for longer range
TRISA = %01111111 '// PORTA.7 = output LED drive. Rest inputs for address
GOTO Encode '// Mode = Encode, jump over sub to Encode routine
Pulse: '// Emits # of 40kHz bursts held in variable Cycles
ASM ;// with auto delay between bursts
bsf porta, 7 ;// 1uS, LED=on [need 25uS total
goto $+1 ;// 3uS (2uS per goto $+1)
goto $+1 ;// 5uS
goto $+1 ;// 7uS
goto $+1 ;// 9uS
goto $+1 ;// 11uS
goto $+1 ;// 13uS
bcf porta, 7 ;// 14uS, LED=off
goto $+1 ;// 16uS
goto $+1 ;// 18uS
goto $+1 ;// 20uS
goto $+1 ;// 22uS
decfsz _Cycles,F ;// 23uS
goto _Pulse ;// 25us
ENDASM
PAUSEUS 500 '// 500uS delay between each data bit
RETURN '// Return to Main
'// Send header pulse + 13-bit data/address packet on keypress
Send:
Cycles = Header '// Load header pulse time
CALL Pulse '// Send 2.4mS header/synch pulse
'// Header sent, now send 8 data bits
FOR Index = 0 TO 7 '// Loop for 8 bits data
IF DBYTE.0[Index] = 0 THEN '// Get polarity of each data bit to send
Cycles = Zero '// Pulse time = 0.6mS for a "0" data bit
ELSE
Cycles = One '// Pulse time = 1.2mS for a "1" data bit
ENDIF
CALL Pulse '// Send Zero or One data bit/burst
NEXT Index '// Loop until 8 data-bits sent
'// 8 data bits sent, now send 5-bit address
'// Shift RA.0 out, RA.1,2,3,4,5=address, mask "zero" upper 3-bits
ABYTE = (PORTA >> 1) & %00011111 '// ABYTE = address from RA.1 to RA.5
FOR Index = 0 TO 4 '// Loop for 5-bits to complete address code
IF ABYTE.0[Index] = 0 THEN '// Get polarity of each address bit to send
Cycles = Zero '// Pulse time = 0.6mS for a "0" address bit
ELSE
Cycles = One '// Pulse time = 1.2mS for a "1" address bit
ENDIF
CALL Pulse '// Send bit
NEXT Index '// Loop until 5-bits sent
PAUSE 25 '// 25mS delay between packets (40kHz bursts)
Encode:
IF PORTB != $FF THEN '// Loop until key-press
DBYTE = PORTB
GOTO Send
ENDIF
GOTO Encode
Decode: '// Shift right to remove bit RA.0
H_Add = (PORTA >> 1) & %00011111 '// AND with %00011111 to mask upper 3-bits
'// RA.1 to RA.5 = 5-bit hardware address
Decode2:
PULSIN PORTA.7,0,PULSE_IN '// Read-in start pulse
IF (PULSE_IN < 200) OR (PULSE_IN = 0) THEN '// Less than Start pulse, then keep looking
Loops = 0 '// Reset Loops on idle or key release
IF LM = 1 THEN Decode '// If mode = latching, don't change outputs.
PORTB = 0 '// Mode = momentary. Key = released or idle
GOTO Decode '// so clear outputs & return.
ENDIF
Verify: '// Read, Decode, then verify data
FOR Index = 0 TO 12 '// Setup to read-in 13 pulses
PULSIN PORTA.7,0,IR_PULSE[Index] '// Read 13 low-going pulses on RA.7
NEXT Index '// Loop x times
DBYTE = $FF '// Start with all 1's and find each 0
FOR Index = 0 TO 7 '// Get 8 "data" bits
IF IR_PULSE[Index] < 100 THEN DBYTE.0[Index]=0 '// Less than 1mS = 0
NEXT Index
ABYTE = $FF '// Start with all 1's and find each 0 in pattern
X=0 '// Initialize address bit index pointer to bit 0
FOR Index = 8 TO 12 '// Get 5 address bits from IR_PULSE bits 8-12
IF IR_PULSE[Index] < 100 THEN ABYTE.0[X]=0
X = X + 1 '// Increment address bit index pointer
NEXT Index
ABYTE = ABYTE & %00011111 '// Mask out upper 3-bits. Result = 5-bit address.
'// Loops is multi-purpose.
'// If Loops = 1, store 1st data & address bytes for comparison on the next
'// pass. Loops is cleared on key release or during idle periods, and is used
'// in the toggle function to determine if a key was released, an idle period
'// occured, or if a key is being held down. If Loops (NOT = 2) on entry to
'// Latch, outputs will not be changed.
Loops = Loops + 1 '// Increment loop counter
IF Loops = 1 THEN '// Record data & address bytes only on 1st pass
DBYTE1 = DBYTE '// Load 1st data byte into verify register
ABYTE1 = ABYTE '// Load 1st address byte into verify register
GOTO Decode2 '// Get 2nd readings for comparison with 1st two
ENDIF
IF Loops = 255 THEN Loops = 3 '// Prevent roll-overs from 255 to 0 & make sure Loops
'// can never be 2 again until the key is released
'// or an idle period
IF ABYTE != (H_Add & ABYTE1) THEN Decode2 '// Does address match?
IF LM = 1 THEN Latch '// Is latch mode selected?
'// In momentary mode, any combination of key-presses are
'// allowed simultaneously
Momentary:
PORTB = ~DBYTE '// Momentary mode set so invert & place data on PORTB
GOTO Decode2
'// Latch mode requires each key to be released before it will toggle
'// the port pin a 2nd time. In Latch mode, only single key-presses
'// are allowed.
Latch:
IF Loops != 2 THEN Decode2 '// Has key been released?
IF DBYTE != DBYTE1 THEN Decode2 '// Do both data bytes match?
FOR Index = 0 TO 7 '// Yes. Now extract data bits
PORTB.0[Index] = PORTB.0[Index] ^ 1 '// XOR port bits to toggle port pins
ENDIF
NEXT Index
GOTO Decode2
END
Compilation Error
Were U Able To Compile The Code With Out Any Errors...
Because I Tried Compiling The Code To Hex File But It Was Showing Errors
Can U Help Me With It
ir rx ic
well i couldnt find the receiver module specified but iam trying it with tsop1738
i am having compilation errors with the picbasic code given on the website
if any 1 has compiled it to hex file i would appreciate it if they paste the hex file
:mad: :mad: :mad: :mad: :mad: :mad:
hex file copiled
may be errors about compiler i used picbasic's internal compiler and i put additional pic description files.
i put in that everything also *.bas file..
  • 40khz_remote_compiled.zip
