hello,
Still using the 18f2550 and the 18f program oshon software.
After being helped with interrupt problem I now have the following problem.....
Is it possible to use analog inputs and interrups together ?
I ask this because if I make it into analog, the ports that are used for interrups are also going to be analog inputs and than the interrups won't work....
If I put the "alldigital" than the interrups will work but than ofcoarse no analog inputs....
Is there an trick to make the a ports analog and the b ports digital (on b port are the interrups) ?
