Simply, unless you need the separate clocks, you can tie them together. All it means is the outputs are delayed by on clock cycle.Data is shifted on the positive-going transitions of the shift register clock input (SHCP). The data in each register is transferred to the storage register on a positive-going transition of the storage register clock input (STCP). If both clocks are connected together, the shift register will always be one clock pulse ahead of the storage register.
