input pull-up GPIOs.
alphacat
Hello fellows.
When the MCU (CC2430) enters debug mode (after burning the code into it), and before I run the code, all GPIOs' outputs are 1 Logic.
Its a problem because I have an external device on the PCB, which 2 GPIOs are connected to it, and it must not receive two 1 Logics at the same time (the device must only receive the pairs (0,0), (0,1) or (1,0)).
I read in datasheet that all GPIOs of MCU are by default set to inputs and connected to pull-up resistors.
My question is, is it the reason why all outputs are 1L?
Meaning, if a pin is defined as input and connected to pull-up resistor, does it necessarily mean that its output would be 1L?
Thanks.
Anyone knows pleaes?
My question is basically:
If a pin is defined as input and connected to pull-up resistor, does it necessarily mean that its output would be 1L?
I just want to know if an input pin can infulence on the external devices connected to it, like a base of a transistor for example.
An input pin is high impedance (resistance). The circuit it is connected to does not know it is there, no influence.
If you use a pullup resistor on that pin, the resistor will pull the pin to a logical one. Just like it is supposed to.
3v0
I you make say GP0 an input and use a pullup resistor to VDD the pin will read as High or 1
And would read as high till you switch it to VSS this shows maybe better
A input reads the pin a output
is what you'd hook the base of a Transistor. You could see if the base went low or high
Thank you guys.
So if a GPIO input pin (which is connected to a pull-up) is connected to a transistor's base, then it could have the BJT conducting current through its C-E junction?
Your not going to do any thing useful with a transistor and a input pin. But see if the transistor has switched on
Thank you guys.
If you mean internal 'soft' pull-ups then yes it will forward bias a attached transistor, however the base current is most likely to be much too low to do anything useful for the emitter/collector path. The internal pull-ups can be quite high in resistance, 20K or greater, but that depends on the specific chip.
Lefty
What chip has the
internal pullup is active
set to on I don't no of any
Most all are input till you set them as output. But you have to enable internal pullup.
With the 8051, which is what I believe you are using, there's no difference between writing a logic 1 to the port when it's used as output and writing a logic 1 when it's to be made an input. You can only tell by looking at what's physically connected to the port. But it won't be able to turn on a transistor due to the internal pull-up.
