Initialising AT89X52
premkumar9
Can anybody send me details on initializing SFRs of 89S52 for serial communication? I mean what are the SFRs and bits to be initialized for different modes of operation?
i am making an obstacle detector robot as my final yr. project. it uses 89s52. i want to know if i can directly connect my ir sensor which uses tsop i.e the tsop output to the microcontroller directly or do i need an adc converter. and if then to which pin of 89s52. plz reply
Hi. See this.
You need to create your own thread for your own topics...
Hi. See this.
I couldn't connect to that link. Anyway thank you for the response. I could get the required details from the data sheet from ATMEL. In fact I used serial communication with some other 8051 family MCs like 89C2051 earlier. For that I got initializing details from a text book. It is my mistake that I didn't go through the data sheet fully before posting this question.
If you need to sense only the presence OR absence of light (only 2 levels) then there is no need for an ADC.
The MC needs digital signal as input (either high OR low). So you need to covert the input to this level and give to the MC input.
All port pins can be used either as input OR output. So you can choose any of those pins as per you your convenience.
From your questions it seems to me that you need to gain some more knowledge on MC before starting the project.
