indirect addressing in PIC16
nitE
Failure Equ 0x30
movlw 0x30
movwf pointer
Incf pointer,f ;next address
movfw pointer
movwf FSR
movf INDF,w
movwf Failure
what i wanted to ask is if Failure points to the address position 0x30 and by using FSR and INDF after the instruction movwf Failure, does now Failure points to 0x31 or the value inside the location Failure(0x30) is 0x31
thanks
No. Neither.
Pointer is loaded with 0x30
Pointer in incremented to 0x31
FSR is set to 0x31
INDF is read into Failure
So Pointer = 0x31, Failure contains the value at address 0x31
No. Neither.
FSR is set to 0x31
so if i change the intruction to
movlw 0x30
movwf pointer
movfw pointer
movwf FSR
movfw temp01
movwf INDF
the value of temp01 will be store in 0x30? is that right
similarly
movlw 0x30
movwf pointer
movfw pointer
movwf FSR
movfw INDF
means w will contain the value at 0x30?
