IGBT or MOSFET?
Archit
Hello people!
I am working on a topology that requires 10A as drain current and 800V as blocking voltage. Also, I want switching frequency to be 175KHz. Is there any IGBT or MOSFET available? Please help me guys. I am a newbie.... Thanking in anticipation.
Edit1- I found DMOS to be helpful.
You should have no issues finding 800V, 900V or even higher voltage mosfets and IGBTs. However at 175kHz I think the mosfet will win in efficiency, but you can do the calculations and see what switching losses and conduction losses you get.
There are many companies that sale parts. Go to one and use their search engine.
If that address does not work then:
Digikey.com
Enter "mosfet"
Choose discreet part.
I click on "active" parts and "in stock"
There is a window for voltage I set to 800 to 1000 volts and in another window 10A to 20A.
Next you can pick what case size or other things.
Mouser.com is also good.
This is a good way to search for parts. You can see the price. You can see how many parts are available.
