IGBT driver gate resistance
neuling
Hi there,
I need to drive IGBT for 3 phase inverter. I have never design driver circuit before. I have found couple of application notes however can not calculate gate resistances (on and off). I need to use PS9552.
I will use 18kHz switching frequency. IGBT average current is 4 A and antiparallel diode current is 0.6 A for nominal conditions.
If you suggest something that would be great.
Thanks in advance...
Since the driver can supply .5 amps minimum I would use something like 20 ohms.
your best bet is to use the number (probably 5 ohm gate resistance) they use on the spec sheet and make sure you are using IGBTs rated for 20KHz min hard switch frequency.
2 reasons.
1. low speed IGBTs are limited by dissipation.
2. miller capacitance might blow the gate when switching with 20 ohms in the gate.
Dan
Yes, watch out for that Miller capacitance effect, also called "gate excursion". This is one I learned in the school of hard knocks. You would think a high value would be fine for the gate on a mosfet or igbt, and... BANG! Whoops.
Thank you so much for your valuable suggestions. I am going to use IKW15N120H3. 15 A 1200 V IGBT. The RMS value of the inverter output is 10 A. I also have to use 18 kHz switching frequency.
you do realize that you have 30W in switching losses alone, dont you? that part will have a 20C rise in temperature from the case to the junction at NO LOAD.
BEWARE SPECMANSHIP!!!
Dan
