IGBT current control circuit
IGBT-s designed typically for switching mode.
What You need? Current generator or power supply unit?
current control
Sebi said:
IDBT-s designed typically for switching mode.
I mean to say if igbt loads are short circuited or over loaded , How to protect IGBT from the above conditions?
The solution always depend from application. Most of applications contains a serial resistor for current sensing,and this current-depending voltage control the driver circuit.
When i see the circuit, can reply correctly.
