Ic Replacement
patz
please can someone suggest a replacement IC for CA3237E which is a infrared remote control amplifier...
INFRARED headphone reciever
thank you for the response ...
i am doing a miniproject on infrared cordless headphones..as per a circuit i obtained from net the transmitter section uses the VCO section of PLL IC CD4046..now i am stuck in the reciever ckt as i am not able to find this infrared preamplifier IC...can u pls tell me the details of the 3 pin reciever ic...
It won't help you, they are for remote control only, and only work with low frequency pulses modulated on a 38KHz (or so) carrier.
You can build an IR preamp using standard opamps, but such high gain systems are fairly tricky to keep stable, even with the specific IC's that used to be available.
I have a set of commercial infra-red headphones myself and I too experience the gain stability problems that Nigel describes. When a movie goes into a quiet passage the gain ramps right up and you begin to hear the hiss of the noise floor. Then when someone fires a gun or a similarly loud action scene breaks in it's deafening.
If I were playing with an infra-red headphone project I think I'd want to address that issue.
Bri
Bri
I have a IR transmitter/IR receiver pair fully working that has the similar problems as to what Brian has described. I chose to go a different route for remote earphones. I chose to use a FM transmitter and a FM receiver.
patz, if you would like to have the IR system that I am not using please send me a personal message, and perhaps we can work something out.
