i am running out of time ~>_<~
i just wish to get some advice on what should i do now.
I m having an embedded web project.
i only got 4 weeks time left.
but my progress is very slow. i 've only developed a User Interface on client, a EKG circuit (without filter). i 've spent most of my time to understand the TCPIP stack.
When i started to write the TCPIP stack code, i realised that i need a proper NIC driver to do so. The RTL8019 driver comes with CCS has some problems....
worst still, the NIC is surface mount type. It can't be done by hand-soldering.
I am panic now. I am very upset now, because I have put my effort on it for 4 months already.
in a bind
The following is just an opinion, but you asked for advice :)
It wouldn't hurt to look at using some off-the-shelf solutions, especially if you're pressed for time. This makes a lot of sense when you're designing prototypes. The time you save by not having to "re-invent the wheel" at every step more than makes up for the small expenses involved. From your posts, it sounds like you're a little out of your depth on this project, so why try to design everything from scratch?
An article by Peter Best in the January issue of "Nuts & Volts" describes a simple ethernet transceiver design based on a 16F877 PIC and a RTL8019AS controller. **broken link removed** (note: it looks like the code uses UDP, a simpler protocol than TCP/IP) http://www.freesoft.org/CIE/Topics/85.htm
The ethernet parts and code can be found here: http://www.edtp.com
Even if it doesn't solve your entire problem, at the very least, the "EDTP Packet Whacker" can serve as a thru-hole adapter for the RTL8019AS (Any NIC chip you find will be surface mount). Best & EDTP did a nice job of taking a fairly complex topic and making a manageable project out of it. You might consider building off their efforts, if saving time is your main concern.
