I²C and RS232 on the same PIC
l30
Ok friends, first of all, sorry for my bad english, it's not my primary language.
I have an average knowledge of analogic eletronic, but just a little of digital, and need some help on a project. I have to READ and WRITE data from a Real Time Clock (in case, a DS1307) using a PC. I've tryed to do it without a uC, but can't make it work so I decided to use one.
I want run an application (that part - send and receive data from the RS232 on the PC side isn't a problem) on my PC that will send via RS232 a command to the PIC saying:"Write the date/Time XXXXXXXX on the RTC", and the PIC will WRITE it via I²C to the RTC.
Or I will say "Read the Date/Time of the RTC" and the PIC will read it and send it to my application via RS232.
From my researches i found out that a PIC16F628 would be the right choice. Am I right?
It is possible to do that? HOW?
If someone can help me with the code and connections, send me some links, tips, anything would help.
I have seen som examples on how to read/write on I²C EPROMS, and was thiking if I can use a similar schematic, but the main problem than it's the uC code.... please, if some of you have the time to help, i'll apreciate a lot.
i have just found this link:
CODE:
SCHEMATICS:
looks like what i need, but not sure about the RS232 part... looks like it is not implemented on the CODE...any idea?
thanks
This might be what you are looking for??
App Note 206: Using a PC's RS-232 Serial Port To Communicate with 2-Wire Devices
the document is a "how-to" for using a cheap PIC to be a translator between PC and SMBus / I2C ... they even include a windows interface program (with code) and a pre-compiled HEX (with source) for a PIC16FL628
just fyi here is a run down of my serial interface project on a PIC18F series!
pic 18F452 that is currently utilizing 4 serial buses:
Serial output to a serial LCD using a general purpose pin
Dallas 1-Wire I/O using a single general purpose pin
I2C Master Mode I/O using the pic's hardware MSSP ports (2 pins)
RS232 via a max232n using the pic's hardware USART ports (2 pins)
there is an occasional glitch with the rs232 when I try to write to the LCD and the RS232 at the same time, haven't quite figured that out
I'm using Proton PicBasic Plus ... there is a free version on their website that might fit your needs.
