humming from speakers
sparkless
I just connected my stero amplifier to my plasma using the plasma's 'Audio out' connection, obviously to get the TV's sound through my amp & good speakers. It worked but the trouble is there is now a loud humming sound comming from the speakers. I had my old tube TV hooked up this way with no problem a few years back, using the same amp & speakers and there was no humming.
Can anyone suggest what might be causing the humming?
MikeMl
Most Helpful Member
Google "ground loop" and "ground loop isolator"
mneary
You can start with:
(a) The plasma and the receiver are plugged into the same surge strip.
(b) There is a lightning arrestor in the surge strip and the tv/cable "antenna" wire goes through it.
(c) The third prong in the surge strip is present, and it is plugged into a properly grounded outlet.
There's a lot more, and Google can get you more, or you can come back here. Bring photos if you can, they help a lot. The ideal photo is about 600 x 400.
sparkless
Thanks for the help.
Since posting the question I did some experimenting.
I hooked up a different amp & there was no humming.
So I took apart the problem amp, vacuumed out all the dust and more importantly
I cleaned up the internal earthing connection.
Guess what, that fixed the problem.
Cheap n easy.
flat5
Good work! Sometimes reversing the AC plug (insert it upside down) helps to reduce hum. Perhaps you also did that.
