Is this an effort to simulate a machine/CNC ball-screw?
If so, and depending on the loading and application, you could possible use a block such as suggested in the DWG, and use two halves with some epoxy/body filler to cast a mold in each side using the screw itself, with suitable grease, it could work.
Thin shim could be used between the halves to control the right pressure/backlash.
e.g.Max.
