#define L1 PORTB, 2
#define L2 PORTB, 1
#define L3 PORTB, 0
#define L4 PORTA, 1
#define L5 PORTA, 3
#define S1 PORTB, 5
#define S2 PORTB, 6
#define S3 PORTB, 7
#define S4 PORTA, 0
#define S5 PORTA, 4
LIST P=16F84A, R=DEC ; Use the PIC16F628 and decimal system
#include "P16F84A.INC" ; Include header file
__config _CP_OFF & _PWRTE_ON & _WDT_OFF & _HS_OSC
errorlevel -302
CBLOCK 0x0C
DelayTMP1 ;Delay-shi sachiro
DelayTMP2
DelayTMP ;Delay-shi sachiro
Level ;Leveli
TMP1 ;Action-shi sachiroa!
SPEC ;Sachiroa: 0-statusia 5-ze meti iyo tu ara.
LAST_TMP
ENDC
;AQ FRTXILAD!
movlw 0x13
movwf FSR
;TRIS Register Configdeba Sesabamisad!
BANKSEL TRISA
movlw b'10001'
movwf TRISA
movlw b'11111000'
movwf TRISB
clrf INTCON
movlw b'00010000'
movwf OPTION_REG ;1KK Instruqcia wamshi
BANKSEL PORTA
clrf PORTA
clrf PORTB
movlw 4
movwf Level
movwf LAST_TMP
movlw 0xFF
movwf DelayTMP1
movwf DelayTMP2
Starter bsf L1
bsf L2
bsf L3
bsf L4
bsf L5
btfsc S1
goto MMMM
btfsc S2
goto MMMM
btfsc S3
goto MMMM
btfsc S4
goto MMMM
btfsc S5
goto MMMM
goto Starter
MMMM
bcf L1
bcf L2
bcf L3
bcf L4
bcf L5
movlw 4
call Delay
movfw Level
movwf LAST_TMP
movlw 0x13
movwf FSR
clrf SPEC
Main decfsz LAST_TMP, f
goto Action ;Antebs naturas da inaxavs M-shi
ZUZUZUZUZ movf LAST_TMP, f
btfsc STATUS, Z
goto UserTime
goto Main
Action movfw TMR0
movwf TMP1
Act_ movfw TMP1
sublw 4
btfsc STATUS, Z
call LED_5
movfw TMP1
sublw 3
btfsc STATUS, Z
call LED_4
movfw TMP1
sublw 2
btfsc STATUS, Z
call LED_3
movfw TMP1
sublw 1
btfsc STATUS, Z
call LED_2
movfw TMP1
sublw 0
btfsc STATUS, Z
call LED_1
btfsc SPEC, 0
incf FSR, f
btfss SPEC, 0
call TMRMinus4
btfss SPEC, 0
goto Act_
;AQ GVAQ ROMELIME LED-i
movlw 0x1
call Delay
bcf L1
bcf L2
bcf L3
bcf L4
bcf L5
movlw 0x1
call Delay
bcf SPEC, 0
goto ZUZUZUZUZ
Delay movwf DelayTMP
JMI decfsz DelayTMP1, f
goto JMI
movlw 0xFF
movwf DelayTMP1
decfsz DelayTMP2, f
goto JMI
movlw 0xFF
movwf DelayTMP2
decfsz DelayTMP, f
goto JMI
return
UserTime movfw Level
movwf LAST_TMP
decf LAST_TMP, f
movlw 0x13;Reset
movwf FSR
KLL btfsc S1
call Switch_1
btfsc S2
call Switch_2
btfsc S3
call Switch_3
btfsc S4
call Switch_4
btfsc S5
call Switch_5
;CHECK IF ANY WAS CHECKED
btfss SPEC, 1
goto KLL
bcf SPEC, 1
;romeligacas daechira
decf LAST_TMP, f
btfsc STATUS, Z
call NextLevel
btfsc SPEC, 2
goto MMMM ;TU BOLOA MIVDIVART MAINSHI!
goto KLL
Check btfss STATUS, Z
goto WAAGE
return
NextLevel incf Level, f
bsf SPEC, 2
movlw 3
call Delay
return
LED_5 bsf L5
bsf SPEC, 0
movlw 5
movwf INDF
return
LED_4 bsf L4
bsf SPEC, 0
movlw 4
movwf INDF
return
LED_3 bsf L3
bsf SPEC, 0
movlw 3
movwf INDF
return
LED_2 bsf L2
bsf SPEC, 0
movlw 2
movwf INDF
return
LED_1 bsf L1
bsf SPEC, 0
movlw 1
movwf INDF
return
TMRMinus4
movfw TMP1
sublw 5
movwf TMP1
comf TMP1, f
incf TMP1, f
return
Switch_1
movlw 1
subwf INDF, f
call Check ;Sworea
bsf SPEC, 1
incf FSR, f
bsf L1
movlw 0x3
call Delay
bcf L1
return
Switch_2
movlw 2
subwf INDF, f
call Check ;Sworea
bsf SPEC, 1
incf FSR, f
bsf L2
movlw 0x3
call Delay
bcf L2
return
Switch_3
movlw 3
subwf INDF, f
call Check ;Sworea
bsf SPEC, 1
incf FSR, f
bsf L3
movlw 0x3
call Delay
bcf L3
return
Switch_4
movlw 4
subwf INDF, f
call Check ;Sworea
bsf SPEC, 1
incf FSR, f
bsf L4
movlw 0x3
call Delay
bcf L4
return
Switch_5
movlw 5
subwf INDF, f
call Check ;Sworea
bsf SPEC, 1
incf FSR, f
bsf L5
movlw 0x3
call Delay
bcf L5
return
WAAGE
movlw 4
movwf Level
bsf L1
bsf L2
bsf L3
bsf L4
bsf L5
movlw 3
call Delay
goto Starter
END
