HOW to
can you post the ASM file because i get errors when copy and paste
"Executable code and data must be defined in an appropriate section"
I dont want to fix the entire spacing heh
I posted on first page:
     #define L1 PORTB, 2
     #define L2 PORTB, 1
     #define L3 PORTB, 0
     #define L4 PORTA, 1
     #define L5 PORTA, 3
    #define S1 PORTB, 5
    #define S2 PORTB, 6
    #define S3 PORTB, 7
    #define S4 PORTA, 0
    #define S5 PORTA, 4
     LIST P=16F84A, R=DEC    ; Use the PIC16F628 and decimal system
     #include "P16F84A.INC"  ; Include header file
        __config  _CP_OFF & _PWRTE_ON & _WDT_OFF & _HS_OSC
	errorlevel -302
        CBLOCK 0x0C
           DelayTMP1  ;Delay-shi sachiro
           DelayTMP2
           DelayTMP  ;Delay-shi sachiro
           Level  ;Leveli
           TMP1 ;Action-shi sachiroa!
           SPEC ;Sachiroa: 0-statusia 5-ze meti iyo tu ara.
           LAST_TMP
        ENDC
      ;AQ FRTXILAD!
      movlw 0x13
      movwf FSR
        ;TRIS Register Configdeba Sesabamisad!
         BANKSEL TRISA
         movlw b'10001'
         movwf TRISA
         movlw b'11111000'
         movwf TRISB
         clrf INTCON
         movlw b'00010000'
         movwf OPTION_REG ;1KK Instruqcia wamshi
        BANKSEL PORTA
        clrf PORTA
        clrf PORTB
        movlw 4
        movwf Level
         movwf LAST_TMP
         movlw 0xFF
         movwf DelayTMP1
         movwf DelayTMP2
Starter bsf L1
   bsf L2
   bsf L3
   bsf L4
   bsf L5
   btfsc S1
     goto MMMM
   btfsc S2
   goto MMMM
   btfsc S3
   goto MMMM
   btfsc S4
   goto MMMM
   btfsc S5
   goto MMMM
   goto Starter
MMMM
   bcf L1
   bcf L2
   bcf L3
   bcf L4
   bcf L5
   movlw 4
call Delay
   movfw Level
   movwf LAST_TMP
      movlw 0x13
      movwf FSR
      clrf SPEC
Main decfsz LAST_TMP, f
   goto Action ;Antebs naturas da inaxavs M-shi
ZUZUZUZUZ   movf LAST_TMP, f
   btfsc STATUS, Z
   goto UserTime
   goto Main
Action  movfw TMR0
   movwf TMP1
Act_   movfw TMP1
   sublw 4
   btfsc STATUS, Z
   call LED_5
   movfw TMP1
   sublw 3
   btfsc STATUS, Z
   call LED_4
   movfw TMP1
   sublw 2
   btfsc STATUS, Z
   call LED_3
   movfw TMP1
   sublw 1
   btfsc STATUS, Z
   call LED_2
   movfw TMP1
   sublw 0
   btfsc STATUS, Z
   call LED_1
   btfsc  SPEC, 0
   incf FSR, f
   btfss  SPEC, 0
   call TMRMinus4
   btfss  SPEC, 0
   goto Act_
   ;AQ GVAQ ROMELIME LED-i
   movlw 0x1
   call Delay
   bcf L1
   bcf L2
   bcf L3
   bcf L4
   bcf L5
   movlw 0x1
   call Delay
   bcf SPEC, 0
   goto ZUZUZUZUZ
Delay movwf DelayTMP
JMI decfsz DelayTMP1, f
   goto JMI
   movlw 0xFF
   movwf DelayTMP1
   decfsz DelayTMP2, f
   goto JMI
   movlw 0xFF
   movwf DelayTMP2
   decfsz DelayTMP, f
   goto JMI
   return
UserTime movfw Level
   movwf LAST_TMP
   decf LAST_TMP, f
   movlw 0x13;Reset
   movwf FSR
KLL   btfsc S1
   call Switch_1
   btfsc S2
   call Switch_2
   btfsc S3
   call Switch_3
   btfsc S4
   call Switch_4
   btfsc S5
   call Switch_5
;CHECK IF ANY WAS CHECKED
   btfss SPEC, 1
   goto KLL
   bcf SPEC, 1
;romeligacas daechira
   decf LAST_TMP, f
   btfsc STATUS, Z
   call NextLevel
   btfsc SPEC, 2
   goto MMMM ;TU BOLOA MIVDIVART MAINSHI!
   goto KLL
Check btfss STATUS, Z
    goto WAAGE
    return
NextLevel  incf Level, f
   bsf SPEC, 2
   movlw 3
   call Delay
   return
LED_5  bsf L5
   bsf SPEC, 0
   movlw 5
   movwf INDF
   return
LED_4  bsf L4
   bsf SPEC, 0
   movlw 4
   movwf INDF
   return
LED_3  bsf L3
   bsf SPEC, 0
   movlw 3
   movwf INDF
   return
LED_2  bsf L2
   bsf SPEC, 0
   movlw 2
   movwf INDF
   return
LED_1  bsf L1
   bsf SPEC, 0
   movlw 1
   movwf INDF
   return
TMRMinus4
   movfw TMP1
   sublw 5
   movwf TMP1
   comf TMP1, f
   incf TMP1, f
   return
Switch_1
   movlw 1
   subwf INDF, f
   call Check ;Sworea
   bsf SPEC, 1
   incf FSR, f
   bsf L1
   movlw 0x3
   call Delay
   bcf L1
   return
Switch_2
   movlw 2
   subwf INDF, f
   call Check ;Sworea
   bsf SPEC, 1
   incf FSR, f
   bsf L2
   movlw 0x3
   call Delay
   bcf L2
   return
Switch_3
   movlw 3
   subwf INDF, f
   call Check ;Sworea
   bsf SPEC, 1
   incf FSR, f
   bsf L3
   movlw 0x3
   call Delay
   bcf L3
   return
Switch_4
   movlw 4
   subwf INDF, f
   call Check ;Sworea
   bsf SPEC, 1
   incf FSR, f
   bsf L4
   movlw 0x3
   call Delay
   bcf L4
   return
Switch_5
   movlw 5
   subwf INDF, f
   call Check ;Sworea
   bsf SPEC, 1
   incf FSR, f
   bsf L5
   movlw 0x3
   call Delay
   bcf L5
   return
WAAGE
   movlw 4
   movwf Level
   bsf L1
   bsf L2
   bsf L3
   bsf L4
   bsf L5
   movlw 3
   call Delay
   goto Starter
   END
I mean post the ASM file itself heh.. well.. i think its called attach...
Attach the file in a post so i can download and dont have copy paste issue
ahaa i got it :))
  • jako.asm
Im having a problem with my MPLAB or something heh...
i get a ton of errors... its not the first time i have seen this so give me a minute...
I have to post my issue on the forum as well...
PM me, maybe I can help...
LOL I found the problem! I had pullups turned on :D:D
right :)) thanks
