How to work out what minimum cmrr I need?
throbscottle
I'm busy trying to choose an op-amp for the input stage to my meter project - got down a few candidates!
It would help if I knew how to calculate what minimum cmrr I need though.
Input source is 10M divider, gain is 2.5 single sided non-inverting, I'm looking at amps with input bias currents of <10pA, load will be about 10K.
Hope this is enough info for someone to start helping me!
Thanks in advance :)
Your amplifier is single-ended (not differential) so the CMRR of the opamp does not affect it.
Actually the common-mode rejection has a theoretical effect since there is a common-mode voltage equal to the input voltage with a non-inverting amp , but the CMRR of most op amps is so high that its effect on the output can be ignored.
Wow, thanks! The field just got a whole lot wider!
