How to work out an IGBT's maximum frequency is from its datasheet.
si2030
Ok I am not an engineer just a keen hobbyst.
I have been looking at a number of IGBT datasheets and some of them indicated the top frequency on the datasheet but the majority do not.
From the details on an IGBT datasheet how can I determine the maximuim frequency the IGBT can operate at?
Kind Regards
Simon
I look at switching times to get a rough idea of what it could do. If it takes the igbt 2uS to turn on and 2uS to turn off, the absolute max it could do is 250khz. Then you need to consider how much switching loss you can tolerate.
those numbers should be /50 to get to hard switched ratings. IGBT speed ratings are closely related to temperature rise due to rise and fall times and NOT to the delay times.
Dan
If you need fast switching a MOSFET is usually better. IGBTs are mostly used in slow speed, high voltage switching applications such as 60Hz inverters.
