I am a complete newbie in electronics so kindly be gentle.
I need to know how to wire an optocoupler 6N136. This is intended to isolate between a parallel port output of 5v to a relay of 24v coil. Based on the data sheet, these are how I understand roughly the following:
Pin 2 - Voltage input to the LED
Pin 3 - Ov of the voltage input to the LED
Pin 5 - GND of Vcc
Pin 6 - Vo (output?)
Pin 7 - Vb (base?)
Pin 8 - Vcc
If I input, say 5v/0v (from parallel port output pin) to Pin 2/3, and 24v/0v (from relay coil's supply) to Pin 8/5, where do I get the output voltage? Between Pin 8 and Pin 6?
Do I need to put a resistor load between Pin 8 & 6 (what value)? Do I need to put as well a capacitor between Pin 8 & 5 (what value)?
What should be the value of resistor before Pin 2 (or is it Pin 4)? Is it preferable to put in a diode in reverse before Pin 2 (or, is it Pin 3)?
If I want to do a complete reversal of the above like isolating a 24v (from a hall effect sensor switch) going to a parallel port's input pin, can I use this same opto 6N136? If not, what can you suggest?
Thanks in advance for all the help and assistance you can provide.
Pin 5 - GND of Vcc
Pin 7 - Vb (base?)
Pin 8 - Vcc
