How to read a 16 bit result issued from ADS8317 ADC ?
crocu
Hello,
I'm trying to write a SPI function that will start a 16 bits conversion with a ADS8317
According to the datasheet, page 8 , i should send more than 22 clocks edges to get the conversion completed and the result returned.
My problem is i do not understand how i should shift or built the 16 bits result integer .
Datasheet says MSB comes first ( after 5th clock edge ) and then LSB comes up.
Can someone lights me, i really don't know how to proceed.
Here is the function i wrote so far :
unsigned int ADS8317_read(void)
        unsigned int pressure_MSB;
        unsigned int pressure_LSB;
        unsigned int ADC_result;
	// Configure SPI
	ADS8317_SPIEN = 0;					// Disable the interface
	// Apply new SPI settings for ADS8317
	ADS8317_SPISTATbits.CKE = 1;     			// Transmit data from active to idle clock state
	ADS8317_SPISTATbits.SMP = 0;    			// Input sampled at middle of data output time
        ADS8317_SPICON1 = ADS8317_SPICON1_CFG;			// Set SPICON1 register
	ADS8317_SPIEN = 1;					// Enable the interface
	ADS8317_CS_IO = 0;        				// Enable CS
	ADS8317_SPI_IF = 0;       				// Clear SPI Flag
	ADS8317_SSPBUF = 0x00;					// Send dummy value (0x00) in order to get the FIRST 8 bit byte
	while(!ADS8317_SPI_IF);ADS8317_SPI_IF = 0;              // Wait until data is shifted out
	pressure_MSB = ADS8317_SSPBUF;                          // Get MSB
	pressure_LSB = ADS8317_SSPBUF;                          // Get LSB
	ADC_result = ADS8317_SSPBUF;      			// Get
	ADS8317_CS_IO = 1;        				// Disable CS
	return ADC_result;
For test purposes, i've applied 2.41V on ADS8317 V+ pin.
V- is grounded.
Vref set to 3.0V
This is the capture of the SPI frame when running the function :
I do not know how to deal with the 3 bytes returned on MISO line
What 16 bits result the following represents ?
How could i verify this 16 bit result is correct and represents 2.41V ?
You'll need three read cycles with the CS bit low..
The first byte received will contain 3 bits
The second contains 8 bits
The last contains the remaining 5 bits.
Be aware that the first bit always seems to be low...
Oh! and the bits represent 0 to 65536 which in turn represents 0 to Vmax
so... ADCin *3.000 / 65535
Your output appears to be 0100111000111000 0r 0001-1100-0111-0010 or 0x1C72
For 2.4 volts I would expect 0xCCC !!!
