How to measure an unknown resistor?
Screech
Whats the correct and safe-to-multimeter way to do this?
Do I set the electronic multimeter to 2meg first, then work my way down the ranges? Or is it the other way?
Also, can I damage the multimeter when measuring an unknown 4.7Meg resistor when setting the meter at 2Meg range?
Hello Screech
You can use it both ways.. there is no posibillity to damage the resistor or the multimeter... just connect the resistor and play with the scale.
checking unknown resistance
:D hi screech,
just make sure that when you measure the resistance the power supply is OFF. :D :wink:
checking resistance
:D hi screech,
if a meter can be invented to measure a resistor resistance while the power is on in the circuit, that person will be an instant billionaire. 8) :lol: :lol:
forgetfulness is inherent to mankind :wink:
Re: checking resistance
Use a combination of a Clamp meter (to measure the current trough the resistor) and a Volt meter (to measure the voltage drop accross the resistor), and you can calculate the resistance ...
...Am I a billionaire now ? ... where's that porche :p
If you'll use the ohmeter to mesure the resistance, take the resistor out of the circuit and measure it... Some of the circuit components may affect resistance...
It would be good if you set the multimeter to the high value of resistance and then start reducing it when you see the symbol "l" in the multimeter.That symbol indicates that you have chosen wrong range for the resistance.
