How to determine divider resistor as the input to ADC?
shteo83
I going to do a digital oscilloscope project. But my ADC is only -0.6v to +2.6V analog input range. I need a voltage id from negative voltage to positive voltage. In my case suppose to get
-2.6v to +2.6. How to the divider resistor? what should be the resistor value? My ref is 2.6v.
the -0.6 and 2.6v comes from the input clamping diodes? , then the recommended is 0-2v for FSD. u need a voltage divider , the measuring range will decide the resistor vals. if u need to measure -ve volts,add a level shifter/dc offset.
The ADC that I am familiar with has an input range of +0.6 to +2.6V so are you sure about the -0.6V ?
If you want the range to be -2.6 to +2.6V then you need to shift the level and attenuate the signal.
This could be done with 3 resistors. Use McMillman's Theorm to calculated the voltages.
My adc is TLC5540INS. It has two option, one is from -0.6 to 2.6 and one is from 0 to 2.28V. Now i care about the 0-2.28v. So how to make it
-2.28vto+2.28?
-2.28vto+2.28?
Feed it from an opamp, setting it's gain and offset to provide the range you need.
In fact, all you need are 2 equal resistors. Their value will depend upon what frequency response you want.
Vin -------R1-------- to ADC input
Then connect R2 from the ADC input to a 2.28 Volt source.
When Vin = -2.28, Vout = 0, and when Vin = +2.28, Vout = 2.28.
R1 = R2
However, you may need an Op Amp configured as a unity gain buffer before R1.
