What is the "phase wire"?
I'm working with ac from 220 Volts to 30,000 volts and I want to know what tools can I use to detect the phase wire.
Phase is a perfectly acceptable term in the UK and Europe.
It is used widley in industry and in engineering.
If I'm interpreting the OP's basic question correctly, he/she wishes to know what tool to use to detect the 220 "hot" wire in a home electrical system (I can't speak to the "30,000" volts issue - that strikes me as a nonsequitor).I'm working with ac from 220 Volts to 30,000 volts and I want to know what tools can I use to detect the phase wire.
I'm pretty sure that UK outlets have the normal Ground/hot/safety(or earth) 3 wire (or plug pin) arrangement.
Nigel,The UK uses 3 pin fused plugs (rated at 13A), with live (brown wire), neutral (blue wire) and earth (green/yellow stripped wire) - so there's nothing to test, the colours of the wires tell you which is which, and the specific pins on the plugs tell you which is which as well.
Nigel,
Is that the arrangement in the appliance plug or the socket?
Reason I ask is that I can see being able to rely on the appliance plugs being predictable (for the most part), but, from experience here in the States, I have come to be very cautious assuming the socket wiring was done correctly by an electrician (or homeowner).
Generally the plugs (or lights, fan, whatever) are wired per code, but on the off chance of an error, for my part, I always check for the hot lead with a meter first, even if I've turned off the breaker for what I think is the appropriate circuit. Been bitten enough times to assume the worst.
And since you'all routinely deal with 220vac, that's twice as dangerous than what is normal for our single phase 110vac (I'm assuming your 220vac is single phase, given your description of the plug wiring)...![]()
Both.
Electrical systems here seem to be a lot better than the states, both in homes, and the infrastructure - cascading failures for example are unknown here.
Makes sense though to ALWAYS double check, you can't usually see where the wires go, and you never know if that particular area you're working on might just have been wired in some weird and wonderful fashion
It's actually 240V here (nominally 230V across the EU, but we're still 240 and the rest are still 220) - basically equipment has to be made for 230, and be happy at >240 and <220.
Single phase here with 3 phase distribution, and alternate houses connected to alternate phases to spread the load evenly.
I don't know as 240V is much more dangerous?, there seems no shortage of deaths in the USA from 110V![]()
But FAR more common in the UK is the 'live' wire, and as he's not an industrial user 'phase' wouldn't be used at all
But as with most of these vague threads, he needs to explain FAR more what he's asking, as it makes no sense.
But the 'answer' is quite simple, the live wire is the brown one that connects to the live pin in the mains plug.
30Kv sounds pretty industrial to me!
Only cowboys and house basher refer to "Live" Engineers and industrial sparks would use the term "Line" or "Phase".
BS 1363-1 specifies requirements for 13 A fused plugs having insulating sleeves on line (or always quoted as live) and neutral pins, for household, commercial and light industrial purposes, with particular reference to safety in normal use.
