Torben said:You also need to think about the antenna design. You could use an omnidirectional antenna which spreads the power out (mostly) equally in a circular shape around the antenna, or a directional antenna which sends more radiation in some directions more than others. That way you can get more distance from the same power, but only in one direction. (Actually it can be more than one direction but the idea is the same.)
So if you're near the centre of the island you might want an omni antenna, say, but if you're near one end of the island (what island? what country?) then you might use a different antenna design so you can direct the signal over the land and not send half of it out over the water.
Audioguru or RadioRon will probably be along to correct me if I'm leading you too far astray--they understand this better than I do.
Torben
