Someone can explain why you place sense circuit in parallel with the load the sense current... if you need to deliver 10 amps to the load, shouldn't the sense circuit be in serie with the load!? I understand that none of the answer would comply but....
Hum... i thought that the power supply set to 10 amps not 10V. In that case, you couldn't measure voltage at load cause if the load changes, the voltage changes. It says that the PSU is set to deliver a constant 10 amps not 10V... that's why I would place sense circuit in series with the load (assuming that the sense circuit impedance is relay ***** low)... Maybe I'm wrong to... it's just i don't understand how you control a current flow with a voltage at an unknown load...
So, in that case, we assume that the load is constant right! That was probably the part I was missing!
