monkeytree
anyone got a secret of how to make decent circuit boards?
Ferric chloride user, how do you get the rust stains off everything?
If the answer is hydrochloric acid, where do you get it from?
Anyone know where ammonium persulphate cn be obtained?
There is a forum on Eagles web site that may help you.Russlk said:Thanks for the reply, yes, no holes any time. The printer problem is the same with me, I had not figured out how to make it work. I have been in contact with Eagle email help, I will ask about the pad holes.
Russ
spuffock said:If the answer is hydrochloric acid, where do you get it from?
Hydrochloric acid is also known as muriatic acid. It's used to [thoroughly] clean masonry, concrete etc. You might check at a local hardware store or building supply center (your location isn't listed though).Handyman said:... so I can't help with where to obtain in from in concentrated form
