Hot Transistor
killivolt
If you wanted to bring down temp on a transistor without decreasing the load would you increase the base transistors wattage to reduce the current or increase the resistance ?
kv
If it's fully saturated increasing the base current won't make any difference, it'll make it worse.
The best way to reduce the temperature is to use a larger heat sink.
Thanks. I'll try.
kv
Heatsink and small fan (ex computer power supply)
