I've played with wind power a good bit over the years.
Never thought of a treadmill motor, though. Excellent concept.
My best success with the "wind" side of things was with a Savonius rotor (vertical axis wind turbine) type of propulsion:
**broken link removed** Top view:
There are many variations in design. The example image might lead you to believe it's for low power applications, but trust me, it can produce remarkable levels of juice.
The first (and biggest) advantage is that it is omni-directional, i.e. , it'll capture energy regardless of the winds' direction. It eliminates the need for a rotating support base and, thus, greatly simplifies wiring. Plus, it develops enormous torque (relatively speaking with regards to a "propeller" type) at very low RPM. They are often used to pump water, which is a very high torque application.
But it is a simple design and not that hard to construct. I've made low power units from two halves of a beer can
. And they can be stacked.
Of course, as with any variable speed generator, you'd do well to have some manner of power control circuitry to maintain appropriate voltage/current levels (as you would with whatever wind driven system you built).
