Hi-Tech LCD example troubble
The bits in PORTA and PORTC change as they should.
The HEX file in your zip had a problem. I did a compile and then it worked.
I will zip the project and you can try it.
Build output
Make: The target "C:\Users\webmaster\Downloads\LCD test_SIM\Main.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\PRO\9.80\bin\picc.exe" --pass1 "C:\Users\webmaster\Downloads\LCD test_SIM\Main.c" -q --chip=16F688 -P --runtime=default --opt=default -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Make: The target "C:\Users\webmaster\Downloads\LCD test_SIM\lcd.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\PRO\9.80\bin\picc.exe" --pass1 "C:\Users\webmaster\Downloads\LCD test_SIM\Include\lcd.c" -q --chip=16F688 -P --runtime=default --opt=default -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Executing: "C:\Program Files\HI-TECH Software\PICC\PRO\9.80\bin\picc.exe" "-oTest lcd.cof" "-mTest lcd.map" --summary=default --output=default Main.p1 lcd.p1 --chip=16F688 -P --runtime=default --opt=default -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
(1273) Omniscient Code Generation not available in Lite mode (warning)
HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode)  V9.80
Copyright (C) 2010 Microchip Technology Inc.
Memory Summary:
    Program space        used    97h (   151) of  1000h words   (  3.7%)
    Data space           used     9h (     9) of   100h bytes   (  3.5%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    Configuration bits   used     1h (     1) of     1h word    (100.0%)
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
Running this compiler in PRO mode, with Omniscient Code Generation enabled,
produces code which is typically 40% smaller than in Lite mode.
See http://microchip.htsoft.com/portal/pic_pro for more information.
Loaded C:\Users\webmaster\Downloads\LCD test_SIM\Test lcd.cof.
********** Build successful! **********
  • LCD test_SIM.zip
Could there be an issue that I use lite edition? (also i havent downloaded the latest version.)
Just neede to change a delay and it works in Proteus as well...
Thanks mate!!
Now for the rest of my project. Read 1-wire (ds18B20P) .. but first I will try to put a variating (button for +/- 1) value in the display.
please help
i want to connect lcd 2*16 in 4 bit on a single portb as follow:
portb 1-4 are connected to lcd data (what ever is pins)
RS: portb.5
EN:portb.6
please help me i want portb.0 for interrupt so dont use it, this connection is just like Mikroc Pro but i dont want to use it because it causes problems
