at24c16a eeprom problem
hello,
i'm using at24c16a with at89c51 but problem is that its not giving the data which i'm writing to it where i'm doing wrong pls help me here i've attached schematic and code in which i'm displaying some data on lcd but it should be stored in eprom first and whenever power fails on next reset it should give the last data stored in eprom .
thank you
$MOD51
ORG 0000H
LJMP MAIN
SCL BIT P3.5
SDA BIT P3.4
LASTREAD BIT FLAGS.0
RD_WR_ROM BIT FLAGS.4
ACK BIT FLAGS.5
BUS_FLT BIT FLAGS.6
_2W_BUSY BIT FLAGS.7
BITCNT DATA 21H
BYTECNT DATA 22H
ADDHI DATA 050H ; ADDRESS LOCATION FOR 24C16 SERIAL-
; EEPROM
ADDLO DATA 051H
COUNT DATA 052H ; STORES THE VALUE OF NO OF INTERRUPT
TDATA DATA 053H
RWDATA DATA 054H
SCL_HIGH MACRO
SETB SCL ; SET SCL HIGH
JNB SCL,$ ; LOOP UNTIL STRONG 1 ON SCL
ENDM
MAIN:
CLR RS0
CLR RS1
CLR P3.6 ;RESET LOW
LCALL DELAY
SETB P3.6
LCALL BEGIN
SETB SDA ; ENSURE SDA HIGH
SCL_HIGH ; ENSURE SCL HIGH
CLR ACK ; CLEAR STATUS FLAGS
CLR BUS_FLT
CLR _2W_BUSY
LCALL SEND_START
MOV A,#00H ;READING FROM LOCATION 0000H FOR COUNT
RL A
ORL A,#0A0H
LCALL SEND_BYTE
MOV A,#00H
LCALL SEND_BYTE
MOV A,#00H
LCALL SEND_BYTE
LCALL SEND_STOP
WER:
LCALL NUMBER1
JNB P0.1,SET12
SJMP WER
SET12:LCALL ESCCLEAR
LJMP SETDATA
BEGIN:
LCALL LCD_INIT
MOV 66H,#00H
MOV R3,#04H
MOV R1,#064H
;MOV R2,#010H
MOV 99H,#00H
MOV 90,#00H ;TO SCROLL ESCON
MOV 91,#01H ;ESC1
MOV 92,#02H ;ESC2
MOV 93,#02H ;ESC3
MOV 94,#02H ;ESC4
MOV 95,#08H ;ESC5
MOV 96,#02H
RET
READ_BYTE:
MOV BITCNT,#08H; SET COUNTER FOR 8-BITS DATA
MOV A,#00H
SETB SDA ; SET SDA HIGH TO ENSURE LINE
; FREE
READ_BITS:
SCL_HIGH ; TRANSITION SCL LOW-TO-HIGH
MOV C,SDA ; MOVE DATA BIT INTO CARRY
RLC A ; ROTATE CARRY-BIT INTO ACC.0
CLR SCL ; TRANSITION SCL HIGH-TO-LOW
DJNZ BITCNT,READ_BITS
; LOOP FOR 8-BITS
JB LASTREAD,ACKN
; CHECK TO SEE IF THIS IS
; THE LAST READ
CLR SDA ; IF NOT LAST READ SEND ACK-BIT
ACKN:
SCL_HIGH ; PULSE SCL TO TRANSMIT ACKNOWLEDGE
CLR SCL ; OR NOT ACKNOWLEDGE BIT
RET
SEND_START:
SETB SCL
LCALL DELU
SETB SDA
LCALL DELU
CLR SDA
CLR SCL
RET
DELU:MOV 23H,#02H
TU
JNZ 23H,TU
RET
SEND_STOP:
SETB SCL
LCALL DELU
CLR SDA
LCALL DELU
SETB SDA ; DELAY FOR BUS TIMING
RET
DELAY_1:
NOP
RET
SEND_BYTE:
SB_LOOP:
JNB ACC.7,NOTONE; CHECK TO SEE IF BIT-7 OF
SETB SDA ; ACC IS A 1, AND SET SDA HIGH
JMP ONET
NOTONE:
CLR SDA ; CLR SDA LOW
ONET:
RL A ; ROTATE ACC LEFT 1-BIT
CLR SCL ; TRANSITION SCL LOW-TO-HIGH
DJNZ BITCNT,SB_LOOP; LOOP FOR 8-BITS
SETB SDA ; SET SDA HIGH TO LOOK FOR
SCL_HIGH ; ACKNOWLEDGE PULSE
CLR ACK
JNB SDA,SB_EX ; CHECK FOR ACK OR NOT ACK
SETB ACK ; SET ACKNOWLEDGE FLAG FOR
; NOT ACK
SB_EX:
ACALL DELAY_1 ; DELAY FOR AN OPERATION
RET
NUMBER1:
SETDATA:LCALL ESCCLEAR
MOV 23H,#00H
LCALL SKIP
MOV R2,#01H
MOV A,2FH
MOV R0,A
LCALL ETWRITE
MOV 23H,#010H
LCALL SKIP
MOV R2,#02H
MOV A,2FH
MOV R0,A
LCALL ETWRITE
LJMP WER
SKIP:
TSZ: JB P0.2,WTZ
LCALL DRT1
RET
WTZ: JB P0.3,TSZ
MOV DPTR,#AA
MOV 2FH,#01H
ACALL DISPLAY
LCALL DRT1
RET
SAVEDATA:CJNE A,#01H,ANS1
MOV DPTR,#AA
RET
ANS1: CJNE A,#02H,ANS2
MOV DPTR,#BB
RET
TRIGR: MOV B,#03H
MOV A,90
MUL AB
MOV DPTR,#TRIGRG
JMP @A+DPTR
TRIGRG: LJMP TRIGR1
LJMP TRIGR2
LJMP TRIGR3
LJMP TRIGR4
LJMP TRIGR5
LJMP TRIGR6
LJMP TRIGR7
LJMP TRIGR8
LJMP TRIGR9
LJMP TRIGR10
LJMP TRIGR11
LJMP TRIGR12
LJMP TRIGR13
LJMP TRIGR14
LJMP TRIGR15
TRIGR1:
MOV R5,#01H
LCALL EEREAD
MOV A,2EH
LCALL SAVEDATA
CLR A
LCALL WRITESCRN
RET
TRIGR2:
MOV R5,#02H
LCALL EEREAD
MOV A,2EH
LCALL SAVEDATA
CLR A
LCALL WRITESCRN
RET
ETWRITE:
LCALL SEND_START
MOV A,#0A0H
LCALL SEND_BYTE
MOV A,R2
LCALL SEND_BYTE
MOV A,R0 ;DATA
LCALL SEND_BYTE
LCALL SEND_STOP
RET
EEREAD:
LCALL SEND_START
MOV A,#0A0H
LCALL SEND_BYTE
MOV A,R5 ;EITHER TH/TL COMMAND BYTE
LCALL SEND_BYTE
LCALL SEND_START ; REPEATED START COMMAND
MOV A,#0A1H
LCALL SEND_BYTE
LCALL READ_BYTE ; READ A BYTE OF DATA
MOV 2EH,A
SETB SDA ; MOVE DATA IN SCRATCHPAD MEMORY
LCALL SEND_STOP
RET
END
