help with PIC16f877 coding
mischa
Hi guys..... i need some major help.... i need to understand the following code as a basis for something i am working on...the problem is i only know c code....can someone convert this assembly code to c for me? please!!! I will attach the files.
Thank you
Plus can someone expalin what this line of code means:
bank2 char i,send,set=1,housekey=0,devicekey=0,onkey=0,name[48]="HOUSE:0DEVICE:0 DEVICE CONTROL USING X10 SELECT";
what is bank2 in the above code???
  • an236.zip
There are thousands on lines of assembler code in that program - you really expect someone to totally rewrite it for you ... ?? !!
Thank you
Hi, I tried to compile your code with MPLAB. I got an error message saying COF file is out of date. Never had that before and i dont know what it means, Hence i cound'nt compile it. If someone compiles it and uploads the .HEX file, i can convert it to C using PIC C Compiler.
full c code for x10 tx and rx
hai..iam also trying to get the source code compleated for x10. pls check this document.....where can i get the decleared functions?
  • powerline-communication-using-.doc
