technogeek
Hi guys,
New here, first post...
I'm looking to build an LED array. I've decided on the HV9910 switcher "buck-boost" supply. It will be powered by mains (120V) and output between 83-130V DC @ 700mA. I followed the application note for designing the circuit, but have never built a switcher before. One thing that concerns me is they wanted a 12uF cap on the output, with low ESR (tantalum or ceramic). Problem is @130V, that's at least $50 worth of caps. I plan on using a $2 electrolytic instead. I don't care if the ripple is huge or efficiency is 30%
But will this cause any other problems? Should I use a larger cap to make up for it?
I'm attaching my circuit diagram (drawn in eagle). If you could look over it, see if anything sticks out I would greatly appreciate it. I know doublechecking my math is probably too much to ask
I wasn't able to find 12uF @250V caps, so I have to use 15uF's on the input and output. I think the input cap is probably too small for the current (>1A) but there's no more space in my box so it'll have to do.
Also, ignore the part number on the central chip. I borrowed one from the atmel library so I could have a DIP socket..... obviously the HV9910 isn't in there and I didn't care to draw it.
