Hi all,
I need to find these two wire crimp lugs for my hair clippers after I cut the wires to shorten them, thinking I might be able to prise them open and reuse. Unfortunately it turned out to be more difficult than anticipated, and have gone and snapped one, the most unique one as well!
Has anyone any ideas where I can find replacements, or a work around? I have been to my local Halfords and electrical wholesalers, but these are so small there's nothing remotely similar. Someone suggested a model train store which I thought possibly a good idea, but it's difficult to explain what I need over the phone without knowing the proper names and for the other person to actually see what I'm talking about. Will add photos here...
They're for 1.5mm wire, and both 10mm in length, crimp section around 3mm wide.
One is an o-ring type with the centre hole 2mm approx.
The other, which is proving the more difficult one, is F shaped at a flat 90° angle, which is necessary to fit inside the clippers body.
Hopefully someone can point me in the right direction . I did see similar things online by doing a reverse image lookup, but they're £0.30 + £20 p+p lol, and not 100% sure they'd work.
Any help appreciated.
TIA
P.s. the second image is showing where the F connector sits, just to give an idea if anyone knows of a workaround, maybe a similar connector that would do the same job?
TIA
