help with building an ssr to drive main line lamp
shosh
Hi
so i need help with an ssr driving 120vac to a light bulb. I have the design of the ssr down, using an optoisolator and a triac to drive the bulb. My problem is working with main line current. I am no way a electrician so i need some help with creating a lamp, and how much current a triac can handle. i need some help to safely implement this lamp into my designed ssr.
You could start by reading the PDF sheet for the triac you're planning on using which you have not named. Or use the parametric search of a site like Digikey to select a triac in the first place.
Even if you don't buy from them Digikey has a great parametric search. Go to their website, type in Triac in the search. Select the Triac option in discrete semi conductors, and it will open a new window with all the various parameters of a triac to filter by.
Sort by off state voltage of your mains level (120VAC) and up. Which is pretty much everything. Assuming a 100 watt lightbulb that's 1 amp, Apply the selection and scroll down and you'll see every triac that can meet your needs, or your can further refine your options.
well my triac is an NTE 56006. I believe this should be able to handle it.
So my main problem is incorporating a circuit using main line to the ssr. Im planning on using a breadboard (so i use something different?) and am not sure if its safe to hook it up to main line. What kind of terminals do you use etc.
If your breadboard is of the usual hobby type it probably won't be suitable for carrying the current your lamp (unknown wattage) will draw, and may not be suitable for 120VAC working either. Better to use chocolate-block type (or similar) terminals to connect your mains-rated components, including the triac.
should i use a wire to board block? or do i need to work on a general purpose PCB. I have not pcb experience, solely breadboards to prototype.
Not sure what that is. Stripboard (Veroboard) would do if you don't want to make a custom pcb.
Simple perfboard and heavy gauge wire. Flesh out the design and solder the connections. If you absolutely need removable connections for part of the circuit, use terminal blocks rated for the current/voltage you'll need. It's not that complicated.
thanks for the replies.
another thing is, I'm building the ssr with an optoisolator feeding into the traic gate. how do i determine what resistor values to use. there will be an Rin resistor fed the the anode of the optoisolator. then i was going to feed a mainline terminal hooked up to one side of the output terminals of the optoisolator and the other pin of the output of the isolator into the triac gate. in general terms, how do i compute the values of resistance i need. the circuit is similar to this **broken link removed**
i have this type of data of the isolator
Viso = 7500v
Pt - 330mW
If - 50mA max
Vf - 1.5v Max
Vr 3v Max
Vdrm - 250v
Ift - 15ma
Ihold - 100uA
and the triac
Vrrm - 400v
It RMS - 15A
Igt - 40/75mA Max
Vgt - 2.5v
Vf(on) - 1.6v Max
Isurg - 150A
I hold - 40mA Max
Hi Shosh
How much of a load is the lamp you plan to light? You have a 50 amp triac which is a pretty beefy triac. At 120 volts that would easily handle about 50 100 watt standard incandescent bulbs.
The reason I ask is because somewhere around here I have several (like a pile of them) complete SSRs. Mostly 5 and 10 amps but some higher. They are complete and only require an input voltage of 3 to 32 VDC to work. It's like the entire triac and driver package in a small single package. If you are in the US (I saw 120 volts) I'll be happy to send you one. I don't want anything for it in return as in free including the postage. They were ripped from AC control systems. If all you want to do is light some incandescent lamps (light bulbs) they should do fine.
Next to answer your question what you care about is If - 50mA max and Vf - 1.5v Max, however, you do not mention the DC voltage you plan to use? The max forward current is 50 mA but the opto would likely work fine with 20 mA. Let's assume 5 volts DC is what you have. It would look like this Vsupply - Vled / I forward so it would be 5 - 1.5 = 3.5 / .020 I led = 175 Ohms so a common 160 or 180 off the shelf would do fine. Again, not knowing the DC supply voltage that being just an example. In reality I would run with between 180 and 200 ohms in the example.
Ron
sorry, i forgot.
input voltage is at 3-30vdc
and im driving 120vac,
im just using a simple lamp circuit to test it
If the input voltage can vary that much you may want to think about adding a zener diode to protect your opto coupler LED and maybe a series 1K resistor. That 3 to 30 volts sounds like a typical DC Control SSR.
Ron
thanks,
so now what about the resistor hooked up to the main line? That was actually the resistor I had questions about
The 180 ohm resistor you see is based on the the maximum surge current of the MOC3010 as that value sets the resistor value, that and the line voltage. The maximum surge current rating of the MOC30xx series sets the minimum value of the resistor using the equation:
R minimum = Vin pk / 1.2 amps as 1.2 amps is the maximum surge current so for 120 VAC RMS the Voltage peak would be 1.414 * 120 = 170 Vpk. So now we have 170 / 1.2 = 142 Ohms so we go over the minimum with a common 180 Ohm resistor. This is not a very exact science and in basic circuits like this using 120 volts you will see values like 150 or 180 ohms used.
Also, keep in mind, the simple circuit you posted is fine for resistive loads on the triac like incandescent lamps. It would need modifications for an inductive load like a small motor or transformer load.
Ron
