Help Wiring a Leeson Motor
J Brenyo
Hi everyone. I'm hoping someone can instruct me on how to connect the wiring to bench test a Leeson 120v reversible electric motor. I've included a picture of the wiring diagram from the side of the motor showing how the five colored wires are currently connected. Here's the sum of my knowledge:
  1. ground is blue, so I should connect the green wire from the 120v input to it
  2. I am assuming that I connect the black wire (hot) from the input to the black wire coming out of the motor
  3. I am not sure if I should connect the white (neutral) wire from the input source to the orange wire or to the yellow wire. The diagram seems to suggest the yellow.... HELP!
I have no idea what to do with the yellow and red wires. HELP!! Thanks for any and all input.
Thanks for your replies. There is a starting capacitor which checks out good. I get that switching 5 and 8 reverses the motor direction, but where do they connect to in the first place? Keep in mind that I am not looking to bench test this with a reversing switch....I just have 3 wires coming in: ground, hot and neutral. How do I connect the 5 wires on one side to the 3 wires on the other side to get the motor to run, regardless of direction?
As I see it, You should end up with the four Black-orange as one pair (Run winding) and white-red as the start winding.
The latter should have the cap in series.
therefore each pair would be in parallel and connected to the L & N.
Thanks for your reply, however, I flunked out of electrical engineering school a long time ago (for good reasons...). So I'm not familiar with the terminology and the schematics. For us simpletons, can you just tell me 1) what wires do I connect the neutral and hot wires from the source to and 2) what do I connect the two remaining wires from the motor to? That would be VERY helpful!
I am guessing that is a 120v240v motor with the connections shown for 120v?
If you have a meter, confirm what the RH & LH pair resistance reads between each conductor
You are correct, it is a 120/240V motor and the wiriing diagram shown is for 120V. Unfortunately I cannot test the resistance as the motor is at my sons house 90 miles away.
