Help to design 3MHz amplifier
shane_ng
Who can help me in designing an amplifier with the following characteristics?
1) Ability to amplify signals from DC to 3MHz
2) Use minimum power (less than 25mV)
3) No distortion
4) Have some level of protection
5) Use minimum passive component
6) Gain should be >100,000
7) Power supply (±12V @ ±9V @ ±5V)
8) β= 200-250
9) Value of resistor less than 10kΩ
Thanks a lot ^.^
It's proably a homework question which he doesn't fully understand.
The origional meaning was probably lost in the translation from Indian or whatever his mother tongue is.
Makes nonsense? I need to design an amplifier circuit to amplify the signal from 0 to 3MHz and also with those characteristics.
As I said, it makes no sense whatsoever - if you want an amplifier then tell us EXACTLY what you're trying to do, if it's homework go back and tell whoever set it he's a complete idiot!.
Yes, it's a homework. We all got no idea with it,so i try to search for some helps here. The problem is he's able to design it.
Nonsense, yes.
2) Minimum power (less than 25mV). mV is voltage not power.
3) No distortion. All amplifiers have distortion. It's just a question of how much your can tolerate.
7) Power supply (±12V @ ±9V @ ±5V). Does that mean it should operate over the range of ±5V to ±12V
8) β= 200-250. β of what?
9) Value of resistor less than 10kΩ. What resistor?
Nonsense, yes.
2) minimum power - may be i copied the wrong term
3) No distortion - just have to minimize the distortion
7) Power supply (±12V @ ±9V @ ±5V) - means can use either one, but not operate over the range
8) β= 200-250 - β of the transistor
9) Value of resistor less than 10kΩ - all resistors in that circuit
Sorry but the characteristics you've mentioned make no sense - I'll go through themn and pick at them if it helps you.
Is 3MHz the 3dB point?
Power is measured in Watts not V.
Also are you talking about the input power output power?
What's the load impedance?
3) No distortion
Impossible, no amplifier has completely no distortion.
What level of protection?
Short circuit?
Over voltage?
What do you mean by minimum?
Passive components are resistors, capacitors and inductors, is there no limit on active components? Can you use 100 transistors but are limited to say three resistors?
That's a very high gain, is there a maximum gain?
Would it be fine if the gain was 1000,000, 000?
Good luck with achieving a gain of 100,000 at 3MHz.
No mention of current draw.
Besides that's a lot of power supplies, surely ±12V is enough.
8) β= 200-250
What do you mean by that?
Is β the gain or negative feedback? Either way you've previously specified a gain of 100,000 which contradicts this.
What resistor, don't you mean the input impedance?
I recommend you politely tell your lecturer that the specification he's given you is total rubbish.:D
He's certainly not designing it to that spec, others have pointed out the individual reasons why not - this is probably why you all have no idea?.
Assuming those are EXACTLY what he gave you, he shouldn't be teaching an electronics class at all, as he hasn't got the faintest clue.
Without specifying a maximum acceptable distortion, its pretty meaningless.
Sounds fair enough.
How many transistors are you allowed to use?
Perhaps he should have specified that you use a specific transistor.
So you're only allowed to use resistor values of 10k and under?
If you need larger values you'll need to make them by connecting 10k resistors in series. Let's just hope you don't need a 1M resistor.:p
Is there any limit to the range of values you can use, for example could you use an 8k resistor (which no one makes)?
