shift left
The << operator shifts the binary representation to the left, dropping the most significant bits and appending it with zero bits. The result is equivalent to multiplying the integer by a power of two.
if you start with
x = 0b00000001
and do
x = x << 1
x will be 0b00000010
you can also shift by more then one bit
x = x << 3
will shift 3 bit positions
'============================== Pin definitions ==============
toneout var PORTA.1
s1 var PORTB.0
s2 var PORTB.1
s3 var PORTB.2
s4 var PORTB.3
s5 var PORTA.2
s6 var PORTA.3
e var PORTA.4
'TX is fixed at MCLR
'============================ variables ======================
tnum var Byte ;tone number from radio
frec var Word ;tone frequency x 5
Define osc 20 ;trick compiler into thinking the crystal is 20mhz, To get better freq resolution.
CMCON = 7 ;Disable comparators, Enable digital functions On PORTA
'=============Main============
toneoff: If e = 0 Then Goto toneoff ;tones are disabled, just idle
