Help needed to modify a single input voltmeter into a 4 input voltmeter
kecax
Can any1 help me to edit the source code attached along to enable RA1, RA2, and RA3 as well and covert the analog signals including RA1 then display all the 4 values on a 4x20 LCD.
Thanks a lot.
[Crystal ball ON]
could this file be a Mikro C modified example file ??? Adc_on_LCD i.e ... or a CCS file ???
[Crystal ball OFF]
unable to open it in any classical way ... system halted.
Alain
No, is not a modified example file.
I think you have to unzip the files to a folder.
I've tried it and it works.
Hope u can help me out.
Thanks a lot.
Ya, I've constructed it with single channel on the breadboard but i haven't try it out yet.
But my friend tried it before, he said it's working.
Thanks.
There shouldn't be much to this. The PIC multiplexes the ADC inputs so all you have to do is loop over each input and convert each one, and display the result in the same way the first is displayed, except obviously at a different part of the screen. Where exactly are you stuck?
16C71 ASM CONVERT TO 16F676 [voltmeter]
16C71 ASM CONVERT TO 16F676 volmeter . but not work .. pl help me
