Help Needed to locate LCD Displays
ks2k
I am trying to locate without any luck the following LCD Display.
This the LCD Glass and PCB. Info stamped on the rear of the Display/Card is;
Toshiba TLX-1013-EQ
H8A
These displays were used in the Magellan Panel Mount GPS receivers. I need 4 of these displays to replace old weak and hard to read displays.
Thanks for your help
KS2K
go to datasheetarchive.com and type that in. Find the company and go to the companies website. Find a vendor/supplier and there you go
Thanks for the info. I just tried it and 'no records found'. Maybe this part no longer exists as its a 1993 unit ?
KS2K
KS2K
Try this forum link
https://uk.search.yahoo.com/search?ei=utf-8&fr=slv8-&p=Toshiba TLX-1013
I would suggest when you do a Google search, omit some of the trailing characters in the part code.
eg:Toshiba TLX-1013-EQ H8A, reduce to TLX-1013 this makes thse search more generic than the precise/full code.
Eric
