Help needed in Designing of two stage CMOS opamp
Gopal Adhikari
Dear all,
I am trying to design a two stage opamp. I have gone through texts to equip with basic ideas to design a opamp. The problem is dont know how to choose the ICMR Values and the values of Vth1max, Vth1 min, Vth3max. The Design Procedure i used is as follows.
μnCox≈246.74 and μpcox≈92.75 * I have calculated using the model file please suggest if I am correct)
Specifications
Gain>=60dB
Power Supply : ±1.8V
GBW=5MHZ
PM>=60°
SR>=10V/μs
CLoad=10Pf
ICMR= ± 1.6V
________________________________________________________________
| at Vin = - 1.6 , Vth1min = 0.31 Vth3min = 0.432 |
| at Vin = + 1.6 , Vth1max = 0.622 Vth3max = 0.433 |
| These values are found using the simulation of the |
| diff amp in the Circuit shown in the opamp.asy file |
| I hope the values are correct. |
|_______________________________________________________________|
Design
1. Cc=0.22*CLoad=2.2pF ≈3pf(adjusted)
2. I5=SR*Cc= 10*3= 30μ
3. gm1=GBW*Cc*2π=94.24μ
(W/L)1= gm1^2/(μnCox*I5)= 94.25^2/(246.79*30)=1.2
4. (W/L)3 = I5/(μpCox[VDD-ICMRmax-Vth3max+Vt1min]^2)
=30/(92.75[1.8-1.6-0.433+0.31]^2) =54.55 ≈ 54
5. VDSSAT5 = ICMRmin-VSS-√(I5/β1)-Vth1max
= -1.6+1.8-0.3182-0.622 = -0.103722 * I am confused about this value as VDSsat5 should be above 100mV
(W/L)5 = (2*I5/(μnCox*VDSsat5^2)) = 22.91 ≈ 23
6. gm6 = 10*gm1 =942.4μ
gm4 = √(2*I4*μpCox*(W/L)4) = 387.62μ
(W/L)6 = (gm6*(W/L)4)/gm4 = 131.28 ≈131
7. I6 = ((W/L)6*I4)/(W/L)4 = 36.38 ≈36
(W/L)7 = (I7*(W/L)5)/ I5 = 27.89 ≈ 28
Using These Values I have simulated the circuit. With these values I assume that the Gain should be >60dB. but I am getting just above -10dB. What am I Doing Wrong. I am stuck, Please suggest me what should I do? I also need to simulate the settling time, psrr, open loop gain and closed loop gain and other parameters of opamp using LTSPICE. please suggest how can I do that too.
Also, When I simulate using ground instead of VSS, I get gain >60dB. ??
I am sorry , the mosfets are named badly in the picture but in the schematics file, its named correctly.
Hope I will be helped
  • tsmc018um .txt
  • opamp.asc
Hy Gopal,
With +- supply lines, ground (zero volts) is the correct reference for the input, not Vss . This is basic opamp theory
spec
spec
can you verify this design using hand calculations or by any other simulators
If you can give a specification sheet for the NMOSFET and PMOSFET and post a complete schematic with no sim voltage and current sources, yes I can have a go. :)
spec
spec
I dont understand what you mean... I have attached a model file .. design specification and it is a simple two stage opamp. it can be found in the internet and as is designed in my post..
The image of the schema is too small and fuzzy to see what you did.
I've attached just the schematic.
What I did:
Disconnected opamp circuit GND and re-connected to VSS.
Connected one opamp diff input to GND, and the other to AC signal input.
Added output label "out".
Performed AC analysis simulation.
What I did:
You edited the schmatics i uploaded? And what u did was "connected a vss instead of gnd, and connected one of the inputs to gnd?
That means design is correct is it?
If thats it... Can u help me to find out the psrr, cmrr, slew rate, and other specs of opamp using ltspice simulation.... ??
Thanks for the help
