help me AT89S52 micro
hi sir,
very very thanks about your attention
now iam connected it ,then
how i can program the micro to generate the A,B and C signals from the micro to make the multiplexer send the byte data to the micro
when ABC are ooo the D0 data will sent to micro and when ABC are 001 the data of D1 sent to the micro and soon until ABC are 111 the last pin D7 data will sent to micro and repeat again continuaslly,
how i can do this
THANKS Mr. rushi53
hi sir,
how i can do this
THANKS Mr. rushi53
Do u wish to send the data continuously ?
I mean without any delay in between
I will give u sample program
Suppose u have done connections as below
Pin A - Port 1.0
Pin B - Port 1.1
Pin C - Port 1.2
               [COLOR="Blue"]ORG 0000H
               JMP START
START          MOV P1,#00H           ;This will turn on D0
               CALL DELAY
               MOV P1,#01H           ;This will turn on D1
               CALL DELAY
               MOV P1,#02H           ;This will turn on D2
               CALL DELAY
               MOV P1,#03H           ;This will turn on D3
               CALL DELAY
               MOV P1,#04H           ;This will turn on D4
               CALL DELAY
               MOV P1,#05H           ;This will turn on D5
               CALL DELAY
               MOV P1,#06H           ;This will turn on D6
               CALL DELAY
               MOV P1,#07H           ;This will turn on D7
               CALL DELAY
HERE           JMP HERE
               END[/COLOR]
And then write the program of delay as per your requirement
if you don't want to use delay then remove the "CALL DELAY" statements.
Let me know if you need any more help
thanks rushi53
but is this program affect the micro time where the micro must sense to multi other inputs and do many other jobs?
and now how i can store the 8 inputs(D0-D7) in the micro ?
i coonect the 74hc151 output pin to p1.5 and set it in p1.5 register but the micro didn't sense to this
I am doing a project based on this micro - controller. and am not getting the pins 21-33......where an EEPROM is connected with a keyboard.
plaese help me out.
