Help!! Checking of Amplifier Gain
chenjk09
Hi everyone,
Can someone teach me how to check the gain of the amplifier I set is correct?
Base on the input of 5mV and 10Hz. How to see from the graph is the gain 25.7 is set correct?
Attach file is how I connect and the output
Hope you guys can help
Thank
Hi everyone,
Thank
With a 5mV peak signal input on a Instrumentation OPA [its effectively doubled as its a push pull signal] and a Gain of 25.7, you would expect an output of 257mV Pk
how to work reverse engineering from the graph? I want to check is the gain is it correct as what i set?
Can't get the gain base on the data sheet
base on the data sheet Page 10 gain equation is G= (49.4k / Rg) + 1
i set 2k for Rg so the gain is about 25.7
i take G= Vout/Vin
i can't get 25.7 what is wrong?
G = (2.5mV*200mV)/(5mV*2) =0.05
so i wrong. anyone can help?
i take G= Vout/Vin
Whats wrong with my post #2, explanation.?
When you say 5mV input signal, is that Vpeak or Vpeak to peak.??
The Vout = 2.5*200mV = 0.5
Vin = 5mVp = 0.01Vpp
Vgain = Vout / Vin
Vgain = 0.5/0.01= 50
So the gain i set is not correct ?
base on the data sheet is not correct ?
